Clad a shed with undercloak/soffit strips
13 Mar 2014
Oxfordshire
I'm building a garden building in a 4.5 x 2.3 metre space at the bottom of my garden enclosed on 3 sides by wooden fences. I want to make maximum use of the space so there will be no room to treat the sides in the future so I am looking for a cladding material that will need no maintenance for as long as possible and is reasonably cheap. Because it is within a couple of inches of fences it does not need to look pretty on 3 sides so I though maybe soffit strips/undercloak may do the job such as link below.
Good or bad idea? I thought these would be more hard wearing than using shed felt! Any other suggestions welcomed! Thanks
[/url]http://www.roofingsuperstore.co.uk/product/fibre-cement-soffit-strips-2400mm-x-150mm-x-45mm-pallet-of-420.html
Ouch thats stuff is expensive.
I am planning on doing a similar thing but using PVC soffit board.
http://www.eurocell.co.uk/upvc-trade/221/soffits
5m lengths of the 300mm wide hollow soffit board like in that pic are about £13.50 per length.
Have a google for your nearest Eurocell branch, Delivery's are free for orders over £50 I think.
They do a rosewood or black one too if you don't want white but its twice the price
Gazman and on the back it will say not for cladding as it is not waterproof, If it something long lasting you want then I would recommend box profile laminated roofing sheets.
mmm It docent say anything on the back.
I like many window fitters/builders have been using it to clad gables, porches and conservatory's for years. I personally have used it for 15 years plus and have never had a call back.
Yes you are not alone in thinking it is a cheap cladding option, but but it is short term solution that is why it is sold as soffit closure. perfect for your 10yr shed life span.
Thanks for the tips I will take a look at the pvc stuff, someone mentioned Fibre cement board and it also has good acoustic properties. I can find manufacturers but haven't found anyone selling it.
You'll need to apply for Building Regulations approval - that will not be a Class 6 exempt building.
I thought I was ok because of number 3 below?
Class 6 (Small detached buildings)
1. A detached single storey building, having a floor area which does not exceed 30m2, which contains no sleeping accommodation and is a building—
(a) no point of which is less than one metre from the boundary of its curtilage; or
(b) which is constructed substantially of non-combustible material.
3. A detached building, having a floor area which does not exceed 15m², which contains no sleeping accommodation.
Yes - you're right - I totally misread Schedule 2 - v. sorry. :oops:
