Anybody know if this cutter will cut 5mm off the length of a 600mm porcelain tile?
The tile is 600mm x 300mm.
5mm needs to be shaved off 300mm.
Tesco.com is the cheapest. I am wondering if the disc will cut this little amount off plus will the table be big enough to support this size tile and big enough to be able to slide it along to cut a straight edge? Thank you.
