Hi
I have a 30yr old house with an open fireplace and a clay lining (within a brick cavity). In the loft I can see through a gap in the brick through to the lining so I am pretty sure there is no filler between the 2 – certainly not all the way up..
Anyway, I wish to remove the open fire and open out the opening (both for width and height) to have a log burner fitted. I am hoping to have the clay liner cleaned but then have a stainless lining installed within the clay liner.
My question is, what is supporting the tall clay lining stack? If I remove the open fire liner is the whole clay lining stack going to then fall down?
With thanks!
With thanks!
