Hello all
We are about to install a new loo as our (very) old s-bend loo, complete with cement collar, is cracked and leaking rather unpleasantly all over the floor!
As with all the posts on this type of thing, what I'm worried about is cutting the cement collar off so we can put the new connector in.
Thankfully, the loo sits on a suspended timber floor which means there is approx 200mm of vertical clay pipe to work with beneath the collar and floorboards. The plan is to angle grind the porcelain s-bend through the top and take the loo away, then we can take the floorboards up and get to the pipe.
But...the pipe exits the ground so close to the corner of the room we can't get an angle grinder into the space to get a clean cut all the way around.
One solution I had (found on here after reading sooo many posts about how we might do this) was to fit a diamond disc to a drill with a nut and blot, but I'm worried about the speed of the drill (ie. too slow) and going slightly off square, putting pressure on the clay pipe and cracking it.
So I keep going back to thinking about hiring a soil pipe cutter. What I can't establish is whether we can use it on a vertical pipe so thought I might post it here and see if anyone can help.
I have been told by a hire shop that it won't work because the chain will slip. But I'm thinking I could make a small frame from 4x2 off cuts, or sit some half bricks around the pipe to help keep the chain in the right place and bob could be my uncle.
Can anyone with some experience of pipe cutters tell me if I'm thinking along the right lines or if it's impossible? All we want to do is get a clean cut without breaking the pipe - and the thought of drilling multiple holes in the collar to crack it off scares the hell out of me!
Help!
Help!
