- Joined
- 8 Mar 2010
- Messages
- 262
- Reaction score
- 0
- Country
I have a f/f maisonette which is rented to some very considerate tenants. I don't know their cooking style, but the outside drain / U bend (just below ground level)frequently blocks with a 'fatball' and results in smelly water flowing over the g/f owners patio.
My tenant has cleared the blockage with a jet washer and I am going to do it again as I have a right angle fitting for car arches that will blast water directly into the U bend.
However, the owner of the g/f property where the issue occurs is quite adamant that I should get a 'professional' to investigate and clean / replace it properly, 'once and for all.' That is unlikely to happen since once cleaned, it flows without any issue for X months. I figure the problem is what is put down the pipe rather than the hardware itself.
My question is, what do 'professionals' use to clean a below ground, 4" U bend? My drain shake kinda refuses to negotiated the bends, as does my 10m long sewer cleaning hose for the pressure washer.
Thanks and toodle pip
