Big 20 year old condensing gas boiler connected to 40+ radiators over 4 storeys, open system, and the heating system hasn't been cleaned in many many years. Had a rad changed and noticed a ton of black sludge in it when I had a play around. Heating engineer recommended having a couple of 28mm magnetic filters fitted in parallel (eg Fernox TF1), a big drain valve fitted (existing ones are tiny 10mm ones), a chemical cleanse, and final top up with inhibitor. Reckoned it was a 1 day job to do that. He was against power flushing so many rads since it would easily be a 2 day job. All sounds sensible to me.
As it's way past my DIY skills I'm going to get a couple of quotes. Is there anything else I should look out for? Any particular chemicals I should hope to hear mentioned in terms of "chemical cleanse"? Is the process really that simple?
