Cleaning a Heating System
12 Nov 2013
Newcastle upon Tyne
Hi
I want to give my heating system a good clean through before having a magneclean fitted.
There seem to be a lot of different chemical from Sentinal, Fernox etc for doing this - can anyone recommend one of the others?
Once's its been run through for a fortnight and drained do I need to neutrilise it or and an inhibitor and if so again reccomended products would be appreciated.
Thanks very much
Steven
It all depends on a lot of information you have not provided.
Make and model of boiler as some have aluminium components
Radiators like wise what are they made of ?
Hot water cylinder for example a Primatic unit has to be treated differently to an indirect unit.
Pete
In most cases Sentinel X800 for 24 hours would be best.
Throughly flushed out afterwards before adding X100 inhibitor.
But best to fit the Magnaclean BEFORE you add the X800 !
Tony
I would suggest just running in the system with the drain valve open and filling allowing the pump to circulate. This keeps the water in the system.
Do that until you have clear water running from the drain valve.
Repeat a couple of times after some circulation has been allowed then add the magnetic cleaner to take care of anything else.
Thanks for your input everyone.
So lets get this right I put the sentinal in AFTER I add the magna clean - not clean drain it out then fit it? Te
