Hi
My central heating has been getting progressivly colder for the past few years. I've taken each radiator off and cleaned a lot of black sludge out of them, which has improved things slightly. I've also cleaned the magnetic filter on the boiler. However I'm concerned that there may also be the same sludge in some of the pipes.
I understand that the next step is to run cleaner through the system for a couple of weeks, before draining it out and replacing with inhibitor, so I've bought a universal cleaner at Toolstation
However it states that it's "for use in indirect systems only". I'm not sure how I can check if mine is direct or indirect. While googling, it seems easy to get confused between direct/indirect heating and hot water. I don't want to run anything through which could damage the system or make things worse.
Can anyone tell me how I'd know if my heating is direct or indirect? It's a Glowworm Betacom2 24 combi boiler.
Many thanks
Craig
Many thanks
Craig
