cleaning ceramic tile
14 May 2005
Whenever I mop my ceramic tile floor, the mop glides over the grout leaving it dirty. Any suggestions on how I can easily clean the tile and the grout at the same time?
A sideways solution - you might like to consider applying a thin coat of black grout on top of the existing colour, then it doesn't matter about dirty marks.
_________________________________
lynda, moderator
I bet he has done it by now, this post was made over a year ago
Am I to assume you have white or a light coloured grout? Sounds like your floor is pretty dirty in the first place. You can't just mop a floor to clean it - try vacuuming it first then mopping. You may need to change the water more often. If you keep on top of it it should be easier to keep clean.
