Emery cloth is best.What’s the best way to clean a copper pipe that I want to cut and add a compression fitting to
The pipe is old with just a bit of emulsion paint on it
It's my cold water so I want it nice and clean, would wire wool do it?
Stop using fairy liquid and man upwear gloves when using the wire wool. It's a pain, (literally), when little bits get into your skin.
When I worked in engineering, my hands were so rough and hard I could hold them under very hot water, (+50ºC), and it felt warm. Didn't stop those little bits getting into your skin and start irritating you a few days later. But it's not a surface irritation that you can scratch as it's sub-dermal.Stop using fairy liquid and man up
will that flush out the copper swarf if I use an hacksaw?Just flush it through at a tap afterwards. Don't let anyone flush a loo while you work.
Use a round file or de-burring toolwill that flush out the copper swarf if I use an hacksaw?
Put your little finger in it while you are cutting it!Excellent, I've cleaned it up nicely with a cheap scotchbrite-type pad and some wire wool
What's the best way to cut into the pipe without filling it full of swarf? I can't get my pipe cutter in as its too close to the wall
we all know you put the little fella in there and had to wrap a sock around him xxPut your little finger in it while you are cutting it!
Follow me for more useful tips!
