cleaning floors
29 Oct 2005
I have had redecoration carried out in a flat. The painters did a lot of sanding of the walls with the result the floor which has been sanded and varnished is very dirty. I have tried washing with soapy water twice but am left which a streaky white residue. I can't afford to have the the floor resanded, what can I use to remove this residue?
heeelllooo valcraw and welcome :LOL: ;)
are you sure its to do with sanding!!!!!
from you description it sounds like white paint smears wiped up but not properly
is it only small areas or a large area
if its small try white spirit but only if its a recent mark [a few days ]!!!
ANOTHER POINT if the wood gets wet under the varnish it can go opaque
perhaps leaving for a while will help!!!
