- Joined
- 1 Sep 2003
- Messages
- 82
- Reaction score
- 0
- Country
I have to replace the mid-position valve, and a couple of rusty rads in my system. Since the system (I suspect) has never been serviced in it's ten-year life, I want to take the opportunity to give the system a good clean-out.
What would be the easiest way to do this?
I'm assuming that I need to get a decent cleaner (anyone recommend a good one?), and put it into the system a few days beforehand. I may get some Fernox system cleaner, which would then have to be followed up with a neutraliser and the system flushed out twice. (or would the less powerful Superconcentrate Restorer do the job on a 10-year old system?)
What is the most efficient method of flushing out the system, in the absence of a power-flusher? Do I need simply to refill the system, run it for a while, then empty it again? Or it it better to attach a hose somewhere and get a more powerful flow of water running through to push the crud out? If so where would you usually tap into the system?
Advise would be much appreciated. Apologies if there is already a guide to cleaning heating systems out on this site, I haven't managed to find it yet.
Many thanks
Paul
Many thanks
Paul
