cleaning heating system
6 Aug 2005
Tyne and Wear
hello everyone
I have identified that my system has sludge in the return pipe from the cylinder coil. it is magnetized. I have a honeywell y plan system with a potterton boiler. I have heard of power flushing ( what does this entail ) as
i would like to try and flush out blockage rather than drain system. Had big air lock problems last time i done it, or is the only way draining.What are the best products for this - fernox?
Regards
Jonny hep
FIrst please do a search! There's loads of stuff here and elsewhere, cos almost everyone's system has some sort of sludge in it!
Look at the Kamco site for info.
You could shut all your rads then drain your pipes, but if you're going to flush , it's the rads which hold most of the gunge.
As you will read, the point where the feed meets the system is often pretty solid and needs mechanical clearing, or the pipes replacing.
jonnyhep said:
hello everyone
I have heard of power flushing ( what does this entail ) Paying vast sums of money to British Gas=owned by Centrica=owned by the French :eek: :LOL:
