- Joined
- 11 Dec 2007
- Messages
- 400
- Reaction score
- 2
- Country
I don't want this question to get lost within the thread of my boiler/water running hot-cold-hot-cold since it's pretty important, or at least to us it is.
For those who helped out, the chap came out today, has scheduled us for powerflushing & a magnetic filter install as suggested in the other thread.
Today though he checked out the heat exchanger & showed me it being full of rusty crap. He used some acid drain cleaner to clean it out which freed up a lot of the crap in it & said this should allow us to have consistently hot water until he's back out in a couple weeks to do the whole system.
My concern is that it's had acid based drain cleaner running through this heat exchanger that water passes through - and whether this will get traces into the water system (tap water) and whether (stupid question maybe) the tap water system is separate from the central heating water system?
Reason i'm asking is because we keep fish & today would be water change day. Obviously i don't want to change the water if the new water will have traces of drain cleaner in.
A seller we deal with had a connection in water treatment. Around winter time a lot of his customers were commenting of their fish dying all at once, yet the aquarium water tests brought back normal results & they couldn't understand it ... yet when posting in the group they were all from around the same area-ish. His connection in water treatment said how the water system gets additive/s, i guess to stop freezing. The aquarium tests don't pick these up but it's obviously enough to kill the fish off.
So you can see why i'm wanting to avoid it.
So will it not get in the system at all? Should i run the hot tap for [insert time length here]? He did flush the exchanger out before fitting it but i don't want to take the chance.
