Ok - I have a Radiant Slim combi-boiler, fitted 1999. It has had services etc but it seems to be one of those appliances that as soon as one thing goes wrong, its closly followed by two more!
Anyway, we recently did some work in a room and had to remove a radiator. When the rad was put back on all was fine. a few weeks later the boiler completely drained itself overnight via the overflow outlet in the wall. Plumber called - problem fixed - dirt on something! 2 weeks later no hot water - plumber called flow valve fixed. 1 day later cold water again - plumber called, thermostat changed.
Bill from plumber arrived with a cover letter to advise that they noticed that the system would benefit from a chemical clean, at £500! We figured that we should be able to use that Sentinal 100 and/or 500 and do it ourselves, but how do you get the liquid into a radiator in a sealed system?? Someone suggested using the fill loop near the boiler, but cant see how to do it.
Also another quick point, since putting back the removed radiator, another radiator in another room has started clicking when the heating system starts up - it is extremely annoying at 4am and has now interupted many nights sleep. We have Drayton thermo valves on all rads, and I have just read that it might be worth changing that one, but any other ideas?
Never had any problems with the 2 seperate boilers pre 99 that were used for over 11 years!!
