Cleaning windows
22 Dec 2007
Suffolk
A little advice, please.
I'm doing some volunteer wardening at a local nature reserve. The windows in the hides there haven't been cleaned for years. I had a crack at some of them yesterday, using a cheap "spray on, wipe off" vinegar-based cleaning fluid and some clean cloths. It shifted the grime, but left them looking very smeary - not the effect I wanted, at all.
Advice would be appreciated on the best equipment/materials/technique for getting these panes crystal-clear, bearing in mind that the budget is minimal, there's currently no water supply on site, and anything I take down there has to be taken on a bus and then carried 3 miles on foot.
Obliged,
Geometer
Geo - once the grime is off use the old window cleaners trick ...
buff with crunched-up newspaper. It really does work and you'll be amazed at how clear the glass will appear.
Excellent, I'll try that. Thanks.
It needs to be damp newspaper though so take some water with you.
