- Joined
- 27 Jan 2008
- Messages
- 25,004
- Reaction score
- 2,894
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My wife said we needed a new microwave, as old one had rust where the wheels of the turntable ran, because the kitchen was designed for the disabled the wall cupboards are mounted lower than normal, so it was a case of carefully measuring the gap, and going around the shops until we found one with stainless steel inside so paint will not wear off again, and low enough to squeeze under the wall cupboards.
At last we found one, Tesco special import, Breville BRGM2316 23 litre with Grill, we will never use the grill, it was size, and having stainless steel inside that made us get it.
However on getting home we finally got the instructions, it states 30 cm clearance on top of it, now since not using the grill I would not think this is really required, no vents in the top, it is a tight fit as was the last one.
Even in our own house I have seen all sorts placed on the Microwave it's a flat surface, so it gets used, I have never had a problem with a microwave as a result. But 12 inches is a large space, and nothing on the advert, only when you get the instructions does it tell you.
Thoughts please.
Thoughts please.
