Clearances round cooker hood over gas hob
4 Aug 2009
Sussex
Instructions for my 600mm cooker hood say it must be 750mm above gas hob.
But can I just slot it 750mm up into a 600mm gap between wall cupboards 470mm above work top or do I need to leave a wider gap between wall cupboards over a 600mm hob? If so how much horizontal clearance should there be?
if instructions quote 750mm above then they can be in line with the hob edges IF you fit them 750mm min above.
