- Joined
- 28 Oct 2005
- Messages
- 31,281
- Reaction score
- 1,997
- Country
Don't know if anyone can help but this is the problem.
Girlfriend has an automatic cleo. For the last couple of days it's been running a bit rough.
Today when she came home from work the car carried on running even though she'd taken the key out of the igntion. I don't mean 'running on' but full all lit up electrics and guages as if the key were still in the ignition (which it wasn't). The only way to stop the engine was to remove the battery lead.
When the battery lead was reattached to the battery all the instrument lights came on as if the key was in (which is wasn't).
I'm assuming that the ignition switch has become jammed inside the barrel and the key no-longer has any function.
The things that seem a little odd are:
Is the misfire/rough running connected or coincidence?
I'm sure I've disconnected batteries before and the car has continued to run by voltage from the alternator (whereas this one stops as if you've turned the key off.
I haven't got a manual at the moment so does anyone know if there are any relays under the bonnet that could be sticking or is it the ignitions switch jammed?
Can you get hold of parts to fix it?
Is is difficult to get the old barrel out and the new one in?
Can you get them from the breakers yard or motor factor or is it a genuine expensive part?
Thanks for any help you can give.
joe
joe
