Any heating engineers out there for advice please?
The problem I have is that on my Worcester 2.4i RSF combi boiler, every now and again it seems to fire up and turn off in quick succession, some times it's fine for a while but once the boiler is fired up for the heating and the water is demanded, this is when the symptoms mostly occur. The radia
tors get hot and the water gets hot, but the switching on and off worries me!
I am a mechanic by trade and have serviced the boiler as the instruction manual (I know I'm not supposed to touch it unless I' m Corgi registered but I'm not exactly flush at the moment)
I'm no gas engineer but my mechanical experience tells me it's some kind of sensor fault, but which one??
If any of you knowledegable people out there point me in the right direction, I would be willing to replace the faulty part if it's within my competence.
The reason I don't ring B gas or N power is I just KNOW they'll turn up and say I need a new boiler for the sake of an inexpensive part!
One person suggested a divertor valve diaphragm as a common fault but this model doesn't have one so no joy there!
The hot water and heating are fine apart from the constant firing up and switching off which occurs every 3 or 4 seconds and also is accompanied by a constant clicking noise at the same time of switching on and off.To give you an idea of what it's like, if you switched the temp. switch back and forth in so doing causing the boiler to fire up and switch off, then this is what it appears like but a lot quicker in succession. You can actually see the burner ignite, 3 or 4 seconds later go out, 3 or 4 seconds later ignite again then after 4 or 5 times it will stay lit for 20 mins. or so and then repeat these symptoms again. It seems to be worse when both the heating and hot water are demanded.
It appears to be a fault that is developing ie. getting worse over time.
I hope this makes sense.
I hope you can help
I hope you can help
