clio III - Dynamique s 1.4 Petrol 2006 immobilizer issue
30 Mar 2015
Hi to all
I have a problem with my
1.4 Petrol
2006
Immobilizer light stays on and if I leave the ignition key on. The dash says low battery. But the battery is fully charged
So far I have changed the fusebox bsi ecu and ignition key coil but it still has the same problem.
Everything else works
I put key turn all lights on dash light up, I turn key once lights go out and nothing. The immobiliser light stays on and 2 minutes later says low battery
Really really confused and automotive electrician does not know what the problem is.
Thank you in advance for any help
kind regards Jess
