I've replaced a diaphragm type check valve on the inlet side of my water softener with a swing type check valve. I did so because of the continuous buzzing noise made by the old valve. The new check valve is silent except when the kitchen tap is turned off and then it clonks. Arghhh! I've now discovered that rubber seated swing valves are also made. Is silent operation the purpose of the rubber seat and if so would it still be silent at mains pressure?
