I've got a bit of a problem with a toilet cistern. Decided to change the syphon as the flush wasn't great (needed several pulls on the lever). Of course, the bolts that tie the cistern to the pan were rusted and needed WD40 to loosen them - fair enough. I got the wing nuts part way loosened, and then the bolts began to spin. Tried to grip the bolts with pliers while turning the wing nuts but no joy.
Ok, I thought, I'll have to hold the bolts inside the cistern with a screwdriver while I turn the wing nuts. But there's no head for the bolts inside the cistern - they're sealed in to the ceramic and not accessible. So I now have a cistern that I cannot secure back to the pan, and can remove from the pan only by cutting the bolts - which of course means I can't re-attached it to the pan.
Other than buying a new cistern (or indeed a new loo), does anyone have any ideas? Seems overkill just to replace a syphon, but I really don't know what else to do....
