Hi, I am trying to replace my cistern that cracked. I have purchased a coupleing kit, and have a large foam washer, a rubber dome and the metal plate. Can any please tell me which order these need to be in.
Thanks all
should go on the same way as old one .
However metal plate should be secured to outside of cistern (ensure you fit right way so securing bolts fit)
Large nut secures it in place either fit doughnut rubber or foam seal to suit wc .
Dont be too over enthusiastic when tightening wingnuts.
