Hi guy. I friend wants to redo her bathroom and wants to change her old low level toilet for a close coupled one. At the mo, the soil stack sticks out of the external wall and connects up sideways to the toilet outlet with a 90 degree cast iron collar. I will have to cut the soil stack but since the close coupled toilet will have to be moved further back to the wall, the toilet outlet will not be aligned anymore with the soil stack. I will have to connect up the toilet outlet with a 90 degree pan connector, add about 500mm of soil pipe towards the external wall, then add a 90 degree elbow, another length of about 300 mm of soil pipe and another elbow to connect up with the soil stack. The bathroom is small and the new distance from the toilet to the soil stack is only about 500 mm but there are going to be a couple of elbows. The slope will be ok as she wants to tile the floor and therefore I could give a couple of cm fall. The one million pound question is can I do that or the toilet will get clogged up because of the two elbows? Also, if the answe to the above is yes, can I connect up the washing machine discharge pipe to the toilet? Thank you for your time and my apologies for the lengthy post.
