I had a quick look at the FAQ but could not see anything related to this.
I have not used the central heating in my house for about three years. The immersion heater provides hot water and that is it. The boiler is switched off, the pump that services the radiators is switched off and the 'central heating switch' is switched off.
Yesterday, one of the radiators sprang a leak - looks like the seal went around one of the front corners (it has a flat face - not a 'column' radiator). Luckily, I caught it before it had time to do any serious damage. I have now closed off both the valves and the radiator is drained.
I would like to know if it OK to do the same with the remaining radiators. The system is 26 years old in a two-bedroom house. There are 5 radiators in total. Is it safe to do this? I don't want any of the remaining radiators to spring a leak due to old age, and isolating each of them seems to be the best bet - if any do leak, then only one radiator's worth of water will be spilt.
Thank you.
Thank you.
