having trouble closing off electrical wiring in our bathroom. I want to remove a light fitting entirely and have a smooth wall.
I took down the light fitting (which has integrated razor socket), and changed the wires over so that the blue and red wires went into a 15amp choc block. I taped over the earth with electrical tape but left it not connected to choc block.
However when I turned the fuse box switch back on it tripped out and the red wire is now singed.
The fuse box is wylex, the light fitting is on a 6amp ring of 13 other fittings with 1.5mm cable size
Getting an electrician in to do a proper fix but what can I do in the meantime to get the lights back on?!
any help much appreciated
