My gut feeling is yes... However, I would appreciate other peoples comments.
I have refurbished a turn of the century property. It's a mid terrace brick under slate with 65mm cavities - brick on both inside skin and outside skin.
I've taken all of the internal walls back to brick and re-wired/plastered (sand/cement) and moved a few things around. I've put 200mm insulation in the loft, 100mm between ceiling joists and 100mm over the ceiling joists.
On the inside skin of the cavity wall I have a top plate that the roof sits on. Between the inside skin and outside skin (the 65mm cavity) should I put any insulation, so that the air between the two cavities warms up, and acts as a 'blanket' for the house. Or should I leave it open, allowing whatever cold or damp air is around to ventilate up and out...
I would really appreciate your comments.
Regards Paul.
Regards Paul.
