I'm trying to replace an old Honeywell chrontherm room thermostat, with a CM927. You move the set point levers on the old thermostat and the boiler fires up and the pump starts and the radiators get warm - perfect.
The old thermostat has 4 wires, brown (live?) blue (neutral?) black(switch) green/yellow(earth) I've wired up the 927 with brown and blue going into the NL, then a link from the second L to A and the switch into B. The wireless remote successfully flashes the green light on the receiver in test mode, try to run through the system test in the manual but all that happens is that the receiver unit click and flashes the green LED a couple of times and then nothing, no boiler or pump running, obviously the relay is not latching but I have no idea why not - any clues?
