CMT927
26 Nov 2010
Buckinghamshire
Currently have a Potterton Suprima HE 60 boiler, with a Honeywell ST6400C controller, and analog room stat.
It's a S-Plan system with 2xHoneywell v4043h1056 two way valves.
Wanting to move the thermostat into the lounge, so looking to get a Honeywell CMT927 for CH timer and thermostat, and a basic hotwater controller such as a Honeywell ST6100C.
Going to get a sparks to do the wiring - just before I buy I wanted to check if this will all work together and make sure I haven't overlooked anything?
Thanks.
There's no need to spend money on a ST6100C for the hot water; the ST6400C will still do the job.
Get the electrician to move the wire connected to the ST6400C CH ON terminal to the L terminal and you will have disabled the CH side of the ST6400C.
