Coarse sand in mortar
11 Feb 2010
Dorset
I have a good quantity of coarse sand left over from laying a flagstone path. Can I use it either instead of building sand for my mortar or as part of the sand mix? I am using it to lay concrete blocks and the look is of no consequence.
If you mix it around 50/50 with building sand it will be ok. Be careful witth the plasticiser as it will turn to slush pretty quick. Dries out pretty fast too.
It will make using the mortar almost impossible, but if you want to use it then fill ya boots.
Don't expect a seasoned brickie to use it though particularly if he's on piecework. :P
I am going to use the coarse sand on the first level bonded to the footing. It is the slowest (for me) laying level. That should use it all up. Cheers
