coil leak in cylinder
31 Jan 2008
Kent
We are having to top up 1/2 bar every 12 hours. I think that our cylinder may have a coil leak.
As we have no evidence of water anywhere else. The motorised valve doesn't appear to ever be off so calls for hot water constantly- this valve has been replaced recently. But still appears to be in the open position its a BG MVSP9-valve actuator(blue)
To prove my suspicion of a coil leak. Can I manually close the valve so that the heating still works and just goes round the bypass radiator.I assume doing this will prove one way or another if there is a coil leak.
If I can't physically shut the valve, If I turn the electric off to it will it stop in the open or shut position? Or is there a simpler way of proving a coil leak.
The hot water tap this supplies, the water hasn't changed colour but it does smell different as in metallic. (PRV and expansion vessel been checked ) Thanks
What cylinder have you got, make and model
and what boiler have you got?
Get BG out seeing as you have one of their valves. :)
Could be under the floor your leak, or the heat exchanger of the boiler, to name 2 places.
i had one recently the way i found it was the tank was filling in the loft the drop was a bit faster than yours but you could see it backing into the cold storage tank ;)
very hard to read without punctuation it all becomes confused punctuation assists the flow it was designed to help understanding is made easier do you agree ;)
