cold air getting into double glazed bay window
19 Oct 2011
Newcastle upon Tyne
just wondering, i have a double glazed bay window and can feel a cold draught constantly from the bottom of each window.this seems to cause excessive condensation on this window compared to others in the house .have had a good look around outside checking for holes/gaps,all seems fine Upon removing the bottom internal beading off one panel,there seems a lot of gaps under the glass which i presume the cold air is blowing into the frame just wondering if this is normal?
many thanks
Test with a lighted candle where you feel the draft(s) check and mark the exact positions and see which way the flame blows. If you are convinced these are lining up with the gaps you speak of, fill the gaps with Plasticine, or something else easily molded and non sticking...pinenot :)
was a bit wary of filling the gaps, thought they may be drainage holes in the frame but the cold air blasting through them cant imagine i need 3 pre cut per window pane i like the idea of the plasticine !
cheers
