Bit of a story, so are you sitting comfortably?
The Aga used to have the bathroom rad connected to it to absorb some of the excess heat from the AGA.
4 years ago I installed a separate boiler and rads for central heating and I disconnected the bathroom rad from the AGA circuit and hooked it into the boiler circuit and it worked fine.
The HW cyl was 20 gallons compared with an ideal 40 gallons.
The EH and coil went in January, so I replaced the cyl with a 35 gallon tank.
This new HW Cyl has good insulation unlike the previous one which had the four red panels strapped to it which came lose and fell to the ground.
But the water from this new HW cyl gets too hot so I reconnected the bathroom rad to the AGA circuit to act as a sink.
But the rad does not heat up so I'm trying to figure why.
The feed for the rad is tapped in the loft, about 3 feet from the expansion tank, to the expansion pipe for the AGA which in turn comes off the flow to the HW cyl.
But the expansion pipe is only just warm in the airing cupboard above the HW cyl, which makes me think that the insulation on the tank is very good and no excess hot water is produced to heat the rad.
The return for the rad is tapped at the AGA return..
The rad bleeds water with obvious pressure so apparent blockage.
If I remove some of the insulation will this cool the HW down?
