Hi
Just after some suggestions as to how to prevent a system airlocking again.
They have an ensuite built a long way from the cold water storage - I'd say the distribution runs a good 20m in the loft space, horizontally (looks to be slightly falling) before dropping into the ensuite. They had an airlock which I pushed out and resolved but apparently this happens regularly. It is supposed to happen when they've been away (they go to Australia regularly for 6 weeks at a time). This seems to bizarre to me cos whenever I've seen airlocked systems before it's usually from the tank draining or air getting in through a leak!
Anyway, I was thinking of fitting AAV but as there doesn't seem to be an obvious high point where the air is collecting, am not sure this will work.
Any views greatly appreciated
Graham
Graham
