I have a back boiler on the 1st floor of the house (3 storey house). The pipes for the ground floor are in the floor of the 1st floor so these pipes feed the first floor and the ground floor (by dropping down to the ground floor). Recently one radiator is cold on the ground floor (large rad 7' x 2'). There is hot water up to the in valve but the rad is cold. So what have I done? Removed rad and flushed, attached hosepipe to in valve and turned on valve - excellent flow. Done the same on the return valve - excellent flow. A small amount of sediment came out of the radiator and out of the return pipe. Reconnected everything and......no difference. Radiator is fully bled, valves are fully on. All other radiators are hot, including the one on the ground floor immediately prior to the cold radiator downstairs. I can think of nothing else to do. Any ideas?
