Hi All,
I have an attached garage that has an 8m single block (100mm thick) and render external wall and a couple of similar build returns either side of a 45mm thick insulated up and over panel door. The other 2 walls are attached the main body of the house.
In winter the garage is almost too cold to use and so I'm part way through an insulation project. I don't need it to be like a lounge, but just a reasonably insulated workshop and gym area where I can be comfortable and not freeze my bits off
So far I've insulated the loft floor above the garage with approx 150mm of fibre insulation roll, with 25mm chipboard on top. Now I need to sort the external walls and have been looking at a foil based solution...something like a YBS SuperQuilt (space saving, easier to install and less mess??). I'm told that with an air gap either side its about the same as 80mm of PIR. I'd be really interested to know if anyone has used this (or any equivalent) and whether there are any tips/tricks and what you thought of the outcome?
Additionally I am getting a bit of damp coming through the wall and so wondering if I should seal the inside of the wall first with something like a Flexiseal 'paint'?
Thanks,
Fred.
Thanks,
Fred.
