I have three radiators downstairs that are fitted from the same line and none of them are that interested in warming up. The flow and return run in parallel for about seven metres with a small radiator at the end, using four ‘T’ pieces the other two radiators are ‘T’ pieced off of the flow and return, the length of their pipwork on each ‘T’ is about six inches as it passes through a wall into another room, Each radiator has a TRV which I am assuming is pretty pointless for the last two in the line but they are set to max anyway. All the radiators have been bled but apart from the first in the line which gets a six out of ten for heat the others remain stubbornly at around two out of ten, lukewarm at best. The flow, as it enters the room from the ceiling is actually very hot…. The rest of the system works brilliantly, just having a problem with this line
