Hello there. We had a leak on the weekend, fairly major. One of the return valves off a radiator went kaput, water everywhere. Anyway, got new 'out' valve for it, sorted. Filled the rad back up and now the heating is up the spout. A couple of rads upstairs are working, and, after several hours, one of the lower rads gets slightly warmer ... but then the upper ones go cool again, like the hot water is taking turns in each radiator. The hot water, now, is absolutely boiling, like its never been before. Its a fairly old system, with baxi (Bermuda??) in the living room, whereby the boiler is behind a groovy gas fire. When this gets going, about every 20 minutes, you can hear the water boiling away, it goes for about 2 minutes, starts to calm down, and then there is a bubbling sound similar to that of a kettle coming to the boil. The pump still hums away, so that isnt cream crackered. We've drained the system, bled all the rads etc, and the pump, and the pipe where in the airing cupboard where the tank sits. Any ideas? Or is it time to call in an engineer?
