cold rad
10 Feb 2008
Buckinghamshire
Hi all
I've just removed the small rad in my kitchen and capped the pipes off.
I didn't drain the system ,I plugged the feed from the expantion tank and the 22mm pipe (vent/expantion??) that bends back into the the tank to create a vacuum.
After removing the bungs and letting a small amount of water back into the system,I then bleed the upstairs rads (a bit of air come from each rad).
After switching the system on the, furthest rad (downstairs) is stone cold, while all the rest are toaster hot!!
Any help for a thickie most welcome :oops:
Turn the other rads off, that should dislodge the air out of the problem rad
