Vailant turbomax combi boiler with 13 rads. The last rad on my system on 1st floor (furthest from the boiler) is cold and only heats up if i turn the rest off.
This is a newly added rad by the previous owner when he had an extension done and it is supplied via plastic pipes.
Do you think that I need to add a second pump to the system upstairs?.
Do you think there are too many rads on the system?.
I have bleed the system and emptied/refilled as I added a rad in the porch.
This problem has been since I owned the property before I did any work on it.
Boiler is working ok as had problems with it that have been repaired be vailant engineer. (in previous thread)
