i just moved into a 1930s house and have a problem with a cold radiator i cant solve..
the radiator is in a conservatory which is onto an extension, the supply pipe is 15mm and t\\\'s off into two 8mm microbore one to extension 2m and one to conservatory 6m.
the radiator in the conseratory has good hot supply but when the lockshield valve is opend it is flooded with cold water from cold return. it seems the cold return from the radiator is of higher \\\\or equal pressure than the feed
is there anything i can do or is this down to bad design.
