I have a baxi boiler system in my house. All the radiators are boiling hot except for upstairs 2nd bedroom which is stone cold. I have bled at the top and there is no trapped air. The valve on the right hand bottom side has a +/- knob and I have turned it to the max plus. The valve on the left hand side is all metal and had a square top. On all other radiators in the house - this valve turns but won't on this rad - the metal has now worn away to make it rounded and I cannot try to turn any more with a spanner. I don't even know if this is the problem! What should I do?
