Hi, I have one raditator that is cold within the central heating system. The other rads are all very hot. The cold rad is the last one, and the pipes going to it from the one before are cold. It seems to go in the rad before the last one hot and return cold ? Im told its a possible problem with the TRV on the last rad which is a tower. That would make sense to me if the pipes coming downt to it were hot. I thought there may have been an air lock in the 2nd to last rad so i opened the filling loop and the drain off point (which is on the last rad) and let the water run through for a while) closed it, toped up the pressure bled all the rads still the same. PPlleaassee help!
