Help!
I have an upstairs rad that refuses to heat up. Every other rad is fine....
On the right side is the thermo stat I assume where I can control the temperature the pipe below it is hot. At the other end the other pipe is cold. When I attempt to bleed the rad the pipe at the other end heats up and hot water feeds into the top of the rad. As soon as I close the rad cools down.
Is the thermo stat duff?
Could the rad be blocked?
What should I do?
What does the small valve do on the left side?
Any assistance greatly appreciated
Regards Rob
