I have a cold radiator in our Garden Room. This room was a garage conversion and I suspect that the offending radiator is the last one to be served with hot water - despite fact it is quite close to the boiler.
There were two rads in the room that were cold but I seem to have persuaded one to work by flushing it, refilling and bleeding. This does not seem to have worked on the other.
I have switched off all other rads in the house and left only the offending rad on. It still didn't heat up so I think I have ruled out balance problem.
The rad filled up ok when I put it back on after flushing. I then switched the system on full blast. The pipe at the base of the rad heated up (v hot) but no water seemed to be getting into the actual rad - v confusing as I managed to fill it through this valve.
I suspect the rads in this room were part of previous owners DIY (talent somewhat patchy!), could he have fitted things the wrong way around? Any other suggestions ? I am going to buy a new thermostatic valve to see if that fixes it.
Apologies for length of e-mail but hopefully more info will help u experts narrow down my prob.
Cheers
Baxman
Cheers
Baxman
