Hi wonder if anyone can point me in the right direction?
I have one radiator (bathroom) which is cold whilst all the rest are okay,
i tried the TRV and found it to be operating freely, i tried bleeding the radiator which had a liitle bit of air but seemed to bleed okay( cold water)
Then went into loft to check pipes and found both the supply and return cold, the pipes go down to the radiators and also are t pieced off to what looks like manual bleed valves? opened the bleed valves and again a little air came out, (pipes became hotter at this point) checked radiator and found no change.
went to bleed pipes again and found nothing came out? checked cupboard with hot water tank etc in this area there is what looks like a pulsation damper with a pressure gauge on it the gauge is reading zero?
Can anyone help me with how i go about getting pressure back into the system? i beleive you need a minimum of one bar?
and does anyone know whats wrong with the radiator?
Many thanks
Many thanks
