Hi there, I hope someone can help, because I'm at my wits end with this stupid radiator! My bedroom radiator has stopped working but all the other radiators in the house are fine. I recently removed the radiator to paint behind it and refitted and it hasnt worked since. It initially filled with hot water and then cooled down never to reheat again. When i tried bleeding it, hot water started to enter it although the bottom of the radiator remained cold. I checked the obvious things like checking that the hand wheel valve with the numbers on it is turned on ( I have it set to 3 at the mo). I also tried turning the spindle on the lockshield valve but it wont budge either direction. Also the pipe attached to the lockshield valve is hot but the pipe attached to the opposite end is stone cold. any suggestions, gratefully accepted!
