Hi everyone
I live in a flat with a Saunier Duval Thelia 23 gas combination boiler. Im certain I have air trapped in the system as the boiler makes a lot of hissing noises and most of the radiators are cold at the top. My problem is I cant seem to find any bleed valves on the radiators - I know where they should be located, but they just arent there. All I can find is a drain valve located at the bottom inlet pipe of one of the radiators - however opening this does nothing - no air or water comes out. Any ideas? Im desperate as its bloody cold! Thanks in advance
