Cold Radiators
22 Sep 2004
Hi, I have two cold radiators in my house downstairs despite bleeding them. When I turn of all rads in the house except these two they heat up perfectly. I then have turned all the other rads in the house one by one, slowly allowing each one to heat up. By the end of this all rads are on and working fine except the two downstairs which begin to cool.
Any thoughts on what the problem might be as a blockage can be ruled out?
system probably needs balancing see other posts as there are lots about this type of problem
I did some balancing on the rads last night and one of them came back good and hot but the other remains cold.
The inflow pipe feels hot on it though, so does this sound like a little bit more "tweaking" / balancing will bring this on line? The two troblesome rads are back to back on a partition wall.
All other rads in the house have stayed good and hot but I am not sure what the minimum amount the out flow valves should be open?
I have similar problem with cold radiator. How is Balancing carried out? Please advise
Thanks alot
Balancing is carried out by adjustment the lockshield valve on each radiator. The Rads closest to boiler should be more closed then those at end of the line to build up pressure.
You should search this site for Balancing as I am not a plumber or an expert on this...
